Old 08-20-2010, 01:37 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Bingo Dugly! I actually ordered #3510 (2") and #2640 (2-1/4"). Your pic in the previous post is right on what I'm trying to do! Still pursuing a flat or slightly lowered base. And, yes, I understand that I can only go as low as the top of the carb, or close anyways.....
Shows that great minds think alike, Michael!
I am currently using the flat base that came with a rather inexpensive aftermarket filter....I trimmed down the circular flange so that the underside of the base just barely clears some "bumps" on the side of the Edelbrock carb I am using, but it sure looks to me like the air coming in from the sides needs to make an immediate 90* turn to get into the carb. I'm hoping that the air coming in the X-Stream Filter top will provide some direct in pressure and help with that transition, but with only about 1/8" to 1/4" between the X-Stream Filter top and the underside of the hood scoop, I'm not really sure that there is much air coming in through the top filter.
One thing of which I am sure, though, is that with the 9" X 2 3/4" K&N filter and the X-Stream Filter top, I'm waaaay ahead of the 9" X 1" paper filter that came with the car. I'd still like to be albe to use that nicely raised and radiused base that came with the X-Stream Filter assembly, though.
One thing to watch for.....the #E-3530 filter that came with your X-Stream Filter Charger assembly has an ID of 8" and an OD of 9", but the #E-3510 filter that you'll be replacing it with has the same OD, but an ID of 7.5".....I'm not sure if there will be any interference with the X-Stream Filter top or not, when you get the replacement filters would you mind posting on this thread to let us know if the greater "thickness" of the K&N filter posed any problems (K&N makes 2" tall 9" OD filters in 7", 7.125", 7.5", and 8" ID's)? I'd appreciate it!
Glad this worked out for you!
Cheers from Dugly
YD,E./PNB
No names were changed to protect the innocent!
