Old 08-22-2010, 03:44 AM
stumpeater's Avatar
stumpeater stumpeater is offline
Cobra Make, Engine: Harrison, VE L98 + T56
Originally Posted by Baz View Post
Hi Andrew and thanks for the interest.34
Fit an 'E' marked Reversing Light, fit Trailing Arms to the rear suspension, re-support the wiring harness in a couple of positions and change over the LED's in the blinkers for globes so I can pass the 'Defective Lamp Telltale' test. Unlike globes, LED's won't flash faster when one of them is removed.
Baz
Has any one else struck Baz's problem with LED globes, do they check flash rates with and without globes as a rule?? Will they be a problem in Vic, or is it just the RTA flexing their muscles again? Thanks, Peter.
Life is what happens to you while you're busy making other plans...JWL
