Old 08-22-2010, 06:51 AM
Barry_R Barry_R is offline
Isky sells a tool for valve pocket work in engine. Or wrap the whole thing in saran wrap and open up only the spot you're working on - like a surgeon does. They forged to pocket walls vertically and the valve is coming down at an angle - poor piston design that dates back to the 70's. Did not matter back then with smaller valves, matters a lot now.
Valves are probably bent - thats why they leak. Might be turnable - or replace. A valve job and trimming the piston brows and your done. Rods and pistons themselves are gonna be fine. Pushrods need to be checked too - might've got bent.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
