Old 08-22-2010, 11:34 AM
undy's Avatar
undy undy is offline
Originally Posted by Jerry Clayton View Post
Great progress
The shake you have might be because you got plug wires 7 and 8 running next to each other and getting crossfire-Ford used to put #7, #5,#6,#8 to stop the cross over---and then on a tune up a mech(or owner) would put them on the plugs like they were on the valve cover and then 3 of them would be wrong---7 on 5, 5 on 6, 6 on 7, 8 on 8!!!!!!
Thank goodness the shake was a couple lifters that had run dry and had to pump up. When I was adjusting the vlaves there were 2 or 3 lifters that had bled down. As soon as they pumped up it all evened out. I've got the end of the plug wires all loomed together making them fool-proof. It was so easy a caveman did it...
It's done...
Everything checks out and no leaks or concerns thus far. I dumped the Dino and put in 10 quarts of Mobil 1. The steering colum is back in, everythings cleaned up and there's a fresh coat of wax on all affected areas. I'm ready for some asphalt action now. Too bad there's a bunch of rogue thunderstorms going through today...
Too many toys?? never!
