Old 01-10-2002, 07:21 AM
ERA535's Avatar
ERA535 ERA535 is offline
scr11,
As the old saying goes, if you have fuel and you have spark, then double check because it must be running!
Obviously you don't have either fuel or spark.
First - you do have (good) fuel from the accelerator pumps, right? That SHOULD mean you have fuel into the combustion chambers. You said you barely stepped on the gas -- well try depressing the accelerator two or three times or put a thimble full of gas directly into the carb.
Next - you said you have spark because the timing light works - therefore you ASSUME that the spark plugs are firing......
There is one good way to find out for sure - remove a plug and crank the engine - maybe the plugs are fouled (what kind of distributor are you using?) or maybe insufficient piston clearance closed all the electodes (if that is possible with your engine - I am not familiar with your kind of engine).
Who assembled the engine?
Good luck!
