Old 08-22-2010, 06:50 PM
Lew Ledyard Lew Ledyard is offline
Cobra Make, Engine: KMP
Epoxy will bubble/peel if there is no moisture barrier under the concrete. To check, tape a 1'X1' piece of Saran Wrap on all sides to the floor for a week or so. If there is any fog or condensation, then you don't have a moisture barrier and the epoxy will lift. Also, concrete takes a LONG time to fully cure (6 months, a year maybe?) and if it isn't fully cured and epoxy is applied, it will lift.
Race Deck is nice, water will flow under it, it can be kept clean easily (although epoxy sweeps up better with less effort) and it isn't slippery. When it is extremely hot for long period of time, Race Deck can buckle very slightly. It is easy to install and is removable, which is a place. It is very durable.
Lew
I'm no expert.
