Old 08-22-2010, 09:28 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by gsharapa View Post
Just saw that the address was posted earlier and as previousley stated I will send the Holley Red Electric fuel pump. Although it's new it's still on the (roller) and it's still 103 plus in Dallas so probably be late next week before I can get it off and ship it.
Update: A bit cooler Sunday am so took the electric fuel pump off and will ship tomorrow or Tuesday.
Parts List – Cobra
Oil Cooler lines and fittings
Remote oil filter bracket - Ford FE
Remote oil filter housing - Ford FE
Air filter and housing
Dipstick and tube - FE 390
Valve Covers - FE 390
Holley 650 dbl pumper carb kit
Cap and rotor – Mallory Unilite Ford FE
Breathers
Summit Chrome Oil Breathere Cap - Push on type - Jim B.
Pushrods - Ford FE
Water pump - Ford FE 390
Cylinder heads - Ford FE to mate to existing Performer RPM intake
Valve springs compatible with Comp 282S cam
Stainless or aluminum water tubes and hoses- radiator upper and lower
Pulleys - Ford FE
Water Pump Pulley - Jim B.
Fan belt
Harmonic Balancer and pointer - Ford FE (Don't worry 767, we won't let Patrickt donate his old balancer )
Engine bolts – external – Ford FE
Alternator brackets – Ford FE
Fuel pump – Ford FE - Gary S.
Fuel filter
PCV plate and basket for rear of intake – Ford FE
Master cylinder – front brakes
Master cylinder – rear brakes
Master cylinder – clutch
Brake light switch and fitting
Headlight relay – Ron Francis Wiring
Braided line from clutch master to slave
Braided lines from three hydraulic reservoir cans to masters
Bracket to hold three hydraulic reservoir cans to inner fender
Ignition coil and bracket
Ignition wires
Spark plugs
Cut pile carpeting for interior and trunk
Vinyl for rear bulkhead inside cockpit
Seat belts
Rear yoke for TKO 600
Driveshaft safety loop
Emergency brake handle, cable and caliper linkage for inboard brake Jaguar rear
Twin batteries for behind passenger seat
Battery cables and terminals (+ & -)
Stock looking horns
Thanks so much, Gary. That pump should work great. I really appreciate you sending it along, it's a huge help. Dallas isn't too far away I hope we get to meet one day so I can thank you properly in person.
Doug
