Old 08-23-2010, 06:46 PM
cobraduke cobraduke is offline
Cobra Make, Engine: SOLD Excalibur, '94-'95 5.0 EFI, Edelbrock heads, E303 cam, 1.7RR, Cobra intake, 24lb injectors, 93 cobra ECU, 65mm TB, hi flow cats.
Default Top Bows
Jim,
Since our cars are wider, I'd think the tops and bows are wider as well. Can't be certain as the windshields are the same. A set of bows for a Classic Roadster II should be the same since it has the same basic dimensions. You might try Double Venom (Ed Combs) to see if he has any leads. You can locate him on the CR II forum on this site. Let me know what you find out.
Mike
