Old 08-25-2010, 05:56 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
We do several of these engines---have done some carbed but with the msd ignition system that is programable--you can even get it from Edelbrock as part of package with manifold--
Lots of drysump parts available from LS7 crate engines that were converted to wet sumps for rods---but you need a crank with a longer nose
if you use the alum block engine it is tremendous weight savings over the iron block
Gasket areas are oring type material within alum retainer--can't over tighten and squoose the gasket out
lots of special tools avail for seal alignment, flywheel tightening etc
bottom ends will take well over 700 hp
ls7 have titaniam rods and hollow lightweight valves
accessory drive components are fairly well tightly packaged( no more fender to fender)
