  #21 (permalink)
Old 08-26-2010, 06:52 AM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Compression can be up to 10.5 on pump gas, or a little higher, because of using aluminum heads.
The pin size is what's normal on a 6.7 BB Chevy connecting rod.
For 527 cubes, the bore is 4.375.
The 4.25 is for a 482 cube I believe.
Correct me if I'm wrong.
Ring pack, I don't know exactly what you mean ?
I will use perfect circle rings.
I'm a bit of a perfectionist so, I don't want to just get by not using correct parts.
Regards,
Kevin
