Old 08-26-2010, 01:13 PM
tnlprt tnlprt is offline
Default Late model trans
WOO late models
They do not use a clutchless trans period
The trans are probably a BERT or BRINN
both of which have an internal clutch
They have 2 forward speeds and reverse
How they work is as follows
you start the engine
place the trans in low to go forward
slowly push down on the clutch pedal to move forward
the farther down you push the pedal the more the clutch locks up
when you have attained sufficient speed
release the clutch pedal and shift the trans into high gear
and away you go
remember never ever jump on it in low or reverse or you will kill the clutch
Oh and reverse is operated the same as low gear
Joe
