Old 08-31-2010, 06:30 AM
Fullchat289's Avatar
Fullchat289 Fullchat289 is offline
Cobra Make, Engine: ERA FIA #2124
Bob:
Do you have a seat on the shelf? If not, how long to make one up? I would need it in about 3wks time. Material is not important, but I would prefer the lesser expensive version. As far as the bolt pattern goes, my comp buckets are fiberglass shells and my chassis number is 2124. Not sure if you can discern from this if your current street seat would be a direct fit.
I also need to talk to one of you guys about a modification to the fuel filler casting weldment piece that goes between the aston cap and fuel tank in support of my Lemans HT project. It's an easy thing, but will probably need to fax a sketch. Would that be Peter I need to talk to?
Also need a couple more side curtain ferrules (2).
Thanks,
- Allen.
