Old 09-02-2010, 08:25 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
I'm interested. What is the part # for the x-treme filter?
If I miscalculate on my Kirkham, then I dent aluminum. I would probably use play-doh first, but has anyone field tested yet?
K&N offers quite a few filters of 9" diameter...here's their search link:
http://www.knfilters.com/search/appsearch.aspx
Go to the right side and click on "Search for filters by Dimension", then click on the 7th category down, "Round Air Filter".
For dimension A (OD), choose 9" from the dropdown menu.
For dimension B, leave it blank, as well as dimension H.
I got a lot of hits, the tallest I found was 3" and the shortest was.....well, I didn't check them all, but you get the idea. They are available with a "thickness" dimension of 1", 1.5", and 2", maybe more, I didn't check further.
The X-Stream Filter top is available separately, looks like black is your only color choice there:
http://www.knfilters.com/search/prod...x?Prod=66-0901
I'd bet there will be adequate range in the height dimension that you won't need to worry about denting that gorgeous Kirkham hood up!
Cheers from Dugly
YD,E./PNB
No names were changed to protect the innocent!
