Old 09-03-2010, 10:19 AM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by Double Venom View Post
Wiring:
Doug, Bobbie would like to know how much if any of the wiring is done? If it has been started / and how much is done if you know. Do you know the brand of harness.
Bobbie is a wiring GURU so no problems there! I just finished an EFI for George Lamb's Cobra, thought I did a good thing, spliced his Air Sensor harness so he could just unplug the harness to take of his air cleaner. Found out, well George found out after his 351 started to run rich/harsh, hard to start all came back to an OEM Ford type splice and plug that I put in thinking I had done a plus.....
Ya right Turns out this sensor runs on mini-volts, with the soldering and the plug the resistance was too high.
Live and learn!
Ed,
It's a Ron Fracis harness, it's physically in place, most things have to be hooked up to it, however. I believe the headlights and fromt marker lights are spliced in, but nothing else is. The dash isn't in place so that's most of the job right there.
