Old 09-03-2010, 10:59 AM
dlotz dlotz is offline
Originally Posted by RICK LAKE View Post
dlotz D try this, take the car for a cruise and get everything to operating temps. 10-15 minutes will do it. Bring a small block of work with you, 2X4", 6 inches long. Tape the ends to protect the paint. Wedge the back of the hood open and waiut 5- 10 minutes and see if the motor fires up easier. I think you are having heat soak problems. Do your coolant fans stay on after the motor is shut down? If yes they have no where to move the air and it stay under the hood. Try this and report back. Rick L. Ps run the fans fOr 1 MInute if the battery is strong with hood cracked.
rick
i have louvers in the good on both sides of the carbs so I have good air flow. I will try the fan meathod tonight and see what it does.
Talked with Barry today and we both think it is a carb fuel issue.
