Old 09-04-2010, 10:54 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
I went back and looked at your fan and a 15 amp load may be about right but it is awful quick and easy to measure so you know for sure. I also recommend you use a circuit breaker that self resets instead of a fuse. A resetting C.B. is a little more bang for your buck. The fuse rating about 25% higher than the normal load should be about right. A diode on the relay or across the load helps to protect the contacts of the relay.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
