Old 09-05-2010, 04:19 AM
Default You have the right setup in your car Rick
Rick Parker In the orginal car that all you needed. You still have enough charging system to add a low ampage fuel pump. Low wattage lights? Do you have a heater and blower fan? You will be close at idle. Watch the amp gauge and see where the needle sits at idle with all the power on. You could also have a 60amp alt in a 42 amp case. Rick L.
