Old 09-05-2010, 04:45 AM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
I discovered the blown out fuse problem tonight....there are times when power is put to the fan that it will not start spinning, but a quick tap on the blades with a screwdriver will get it started..... Guess that means it is time to buy a new fan.... (Will be the third fan in less than a month) I will try to find the post here on Taurus fans, but any other suggestions? If I recall the dual pusher fans are quite pricey, so a basic puller fan will most likely be the way to go. Thanks.
"Freedom is only an illusion when the government has all the guns."
