  #39 (permalink)
Old 09-05-2010, 05:00 AM
patrickt patrickt is offline
Originally Posted by azfordman View Post
(Will be the third fan in less than a month) I will try to find the post here on Taurus fans, but any other suggestions? If I recall the dual pusher fans are quite pricey, so a basic puller fan will most likely be the way to go. Thanks.
Three fans in one month?!? Make sure the wiring connections are not "iffy" that then go from "iffy" to "bad" when the current draw increases. That could be behind your fan failures.
My pushers are mostly for the looks. The puller does the lion's share of the cooling.
