Old 09-05-2010, 01:19 PM
BigE BigE is offline
Cobra Make, Engine: SPF MkIII, FE Stroker
Thanks Steve,
Typical Sunday drive around Sonoma. Properly warmed up. I did a quick 3rd gear blast to about 5,500 and went for 4th and it ground a bit and wouldn't go into gear. I pushed in the clutch and slowed to stop. Started off again and very lightly shifted up 1st through 5th, everything was fine. I pulled up to a light and started the normal downshift routine and it would not come out of 5th gear.
I had a friend with me, so we shut it off and tried rocking the car back and forth in gear with one of us pulling on the lever to get it out. It would not budge. I could feel movement inside the tranny against the lever when we were rocking the car. We tried again to pull really hard on the lever to get it out of 5th with no luck. I was close to home and it has monstrous TQ, so I was able to limp home and put it in my garage.
Any thoughts? Additional info needed?
Thank you,
- E
