Old 09-05-2010, 05:13 PM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
I did some carb adjustments today...raised the levels in the float bowls, they were actually pretty low, and I put in larger jets. I have not had a chance to drive the car car yet, because the second fan did burn out while I was idling the car..... With the heating problems I have been having and two dead fans already, I am not sure if I want to trust a junkyard fan....so on Tuesday (I hate holiday weekends) I should be able to go to an auto parts store and buy a fan for a 90-95 V6 Taurus, 3.8....is that correct? The relay I have installed is a 50 amp....so what size wire should I use for the main power supply and to the fan? Should I use the same heavy gauge wire for the grounds and to the switch as well?
"Freedom is only an illusion when the government has all the guns."
