Old 09-05-2010, 11:18 PM
tin-man's Avatar
tin-man tin-man is offline
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Originally Posted by Rickd View Post
ANY new motor .. aluminum or steel .. you are going to need to check your cylinder head bolts and exhaust manifold bolts after a couple thousand miles. Bolts will vibrate loose and simply need to be tightened. NOT OVER TIGHT.
Rickd, is there a spec for how tight these bolts should be? While I do not have my Cobra yet I will soon and am just curious as to what the torque wrench setting should be. tin-man
Be well, drive fast, live long
