Thread: Overheating!!
Old 09-06-2010, 08:26 AM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
I hate hot engines !!!
Verify you have at least 30* ignition timing at 2700 RPM.. this is a min. not a target
verify your crank pulley is larger than water pump pulley by a min of 15 %
V you have a working 180* T-stat and it is not being bypassed (rad cool until t-stat opens on start up)
I place fan sensor in rad to turn on fans if temp above 180* (this allows fans to cycle)
I have a manual fans on - dash switch so can turn on in traffic .... period
air / fuel ratio a little fat helps cool engine. lean mix runs hotter check what you have
you never specified when or how it was overheating... IE. only in traffic but cools at freeway speed or only when on the freeway or stop n go starts overheating and won't recover once she starts to get hot or ??????? GOOD LUCK be patient
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
