Old 09-07-2010, 03:27 AM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
I had a couple of Holley 4 barrels sitting here and I took them apart to look at the jets. They were all #61 jets, same as the carb currently on the car. The two carbs I took apart did not look like they had jets in the secondaries, which I thought there would be, just a flat plate bolted to another plate and gasket. The inner plate would not come off without major force, so I left it alone. Since I had an abundance of #61's, and it was a holiday weekend, I decided to drill a couple of them out (not recommended, I know), but it would give me an idea of the stumbling/backfire problem is from a lack of fuel. Took the car for a drive at night since it was cool enough not to need a fan and it actually ran a lot better!!! Ran very well under hard acceleration. A couple of questions for those with a bit more experience...when I am at a higher speed (mph) in a higher gear (4th or 5th) and very low throttle and RPM, say 1,200-1,400 there is still a noticeable miss and stumble. Not bad and not that often, every few seconds and just enough to notice if I am really paying attention....I know that the engine has high compression, don't ask how high, I don't know, but I cannot rotate the assemble by hand and I cannot push start the car (it just stops dead when the clutch is dropped) and I do not know if the engine has any cam at all....it is not radical, but when idling it does have a decent lope. Could this, slight stumble and miss at low throttle, be normal for this engine? Or should I continue to trouble shoot the ignition system? It is starting to run very well WOT, but we all know these cars cannot be driven that way regularly!!!!
"Freedom is only an illusion when the government has all the guns."
