Old 09-07-2010, 04:58 PM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
Does it stumble right off of idle? How do you have your idle set? All on the primary side? Or do you have a little bit of the secondaries opened up too?
The carb only has idle adjustment screws on the primary side. Secondary throttle plate is closed 100% at idle. Took the primary screws in all the way, backed each one out 1/2 turn and hooked up a vacuum gauge. Increased the idle screws until I achieved maximum vacuum, then backed each one in a hair to drop it 1 hg of vacuum....kinda tough because the vacuum is not steady....the needled bounces and fluctuates around 1-2 hg, but is strong around 21 hg. The car idles fine...just a bit of a lope to it. There does not seem to be any miss at idle....only when cruising with minimum throttle, if I down shift and kick the RMP's up the stumble/miss goes away.
"Freedom is only an illusion when the government has all the guns."
