  #60 (permalink)
Old 09-07-2010, 07:46 PM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
What kind of carb is it? You may be into the transition circuit on the primary side, which will cause a stumble when you're in between the idle circuit and the jets.
The carb is a Holley 600 I believe, #80457-1, took it off of my 84 Bronco that has a 351w as well. If you read this entire mess of a post, the carb that was on the car, a Motorcraft by Holley #50264 would vapor lock after 10-15 minutes of driving in the heat. Putting the Bronco carb on the car solved that problem. I will have to pick up some jets in the next few days, since I am sure that the home drilled jets will not be ideal. Between the larger jets and the timing I think I may be in good shape. I still may want to put a better carb on the car....not sure if a Holley that was on a full size Bronco is the best application for a car like a Cobra....what do you think Brent?
"Freedom is only an illusion when the government has all the guns."
