Old 09-08-2010, 10:12 AM
blykins blykins is offline
Originally Posted by T300zx View Post
It was very nice talking to you as well Brent,you are deffinetly gonna be my tranny guy,we will talk about engine builders,but i have a guy out of California where i'll be moving thats building me 460 stroked to a 533 built motor,390 cfm aluminum heads,10:1 compression run on 91 octane. The motor will make 680ish HP and 720 ish ft lbs of torque,and i get a free dyno for $8499 that is a unbeatable price,but i still will take a listen to your suggestion,but that will be a really really really tough act to follow.
I checked out that source and looked at the list of parts. What scares me is that no brand names were listed and there are many off-shore crankshaft/rod/piston/cam manufacturers right now (Hawk Racing, RPM, Pacific Pro, etc) and with this kind of pricing, I'm sure that's what they're using. The only brand name I saw was ARP and even it was spelled wrong. There was also not a mention of MSD/Mallory ignition products....I suppose I could assume he's using Procomp for ignition?
There were a lot of things missing for a turn-key setup: coil, plug wires, wires, pulleys, PCV valve, water neck, thermostat, air cleaner....basically all the things that add up when you're going for a turn-key.
I use quality parts in my builds...Scat, Callies, Probe, Wiseco, Comp Cams, ARP, MSD, Canton, Moroso, etc/etc.
You get what you pay for...
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
