Old 09-08-2010, 01:06 PM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
The motor has a standard distributor with a vacuum advance. With the cap off I can manually apply vacuum to the hose and it get it to move, so it does work. When I get a chance I will measure manifold pressure under slight throttle, and I will check to see at what RPM the advance kicks in, although if I recall it seems to kick in right away. I will keep you posted.
"Freedom is only an illusion when the government has all the guns."
