Old 09-09-2010, 08:05 AM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
Originally Posted by Car Nut View Post
Did the fuse blow or the relay?
Did you use at least a 12 ga wire for the fan power and ground?
Is your control circuit still hot?
Are you sure your ground(s) is good?
Fuse is fine
10 ga wire used
Not sure what you mean by control circuit....but, there is power from the + connection to the starter relay....hot at relay & power from the ignition switch +....hot at relay & ground is good at the relay from the switch. No power comes out of the relay to the fan when switch is flipped...... If I put 12v to the fan connection at the relay the fan comes on. Fan is good.
Relay is bad......
I am sure the answer cannot be buy a new relay every other day.......
"Freedom is only an illusion when the government has all the guns."
