  #35 (permalink)
Old 09-09-2010, 10:21 AM
Car Nut Car Nut is offline
Originally Posted by azfordman View Post
Fuse is fine
10 ga wire used
Not sure what you mean by control circuit....but, there is power from the + connection to the starter relay....hot at relay & power from the ignition switch +....hot at relay & ground is good at the relay from the switch. No power comes out of the relay to the fan when switch is flipped...... If I put 12v to the fan connection at the relay the fan comes on. Fan is good.
Relay is bad......
I am sure the answer cannot be buy a new relay every other day.......
I'm at loss, the only other thing I can think of is low voltage and Ohm's Law. If you have a lower voltage your amperage will go up. 40 amps at 12 volts will equate to 48 amps at 10 volts. However since it did not blow your 40 amp fuse, I suppose it can be you just happened to be lucky enough to get a bad relay.
Its also possible you could be getting a voltage spike in which case you may need to add a diode. http://www.the12volt.com/relays/relays.asp
Maybe the easiest thing would be to replace it and see if solves the problem Maybe add the diode at the same time?
