Old 09-09-2010, 08:34 PM
michel schryer michel schryer is offline
Cobra Make, Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
Default Maybe not the cap that's leaking ??
I have the same problem right now with the remote plastic wilwood reservoir leaking from the bottom. Clean it good,go for a drive and check around the cap first and go down to the split where the oring is. I took it out,cleaned the oring and i changed the golden clamp for a regular hose clamp and I will see what happens. I have three reservoir and only one is leaking,probably because of the clamp not doing the job. I will replace those plastic reservoir eventually for better ones,plastic look cheap.
Michel
Originally Posted by madmaxx View Post
I had something similiar on a remote reservoir and finally determine it was the bottom leaking not the cap. It was a plastic wilwood remote resvoir that used an o-ring to seal the bottom with a clamp. After screwing around for weeks, I disasseamlbed, put SEALALL on the o-ring and not a drop in two plus years.
