Old 09-11-2010, 11:25 AM
Snakebit's Avatar
Snakebit Snakebit is offline
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
Most of the time oil consumption on a new motor is caused by a leaking intake manifold gasket or damaged oil seals when they installed the springs. I replaced the intake manifold 3 times using different types of gaskets until it stopped leaking. I used a plain SCE gasket with the hylomar sealer that was made for use on Rolls Royce aircraft engines.. The stuff is great, but no one has ever herd of it. I won't use anything else. I even used it on my valve cover gaskets. You can take them off anf put them back without additional sealer. I tried Nitro seal, printo seal and Victor Reinz they all leaked! The gaskets were hard as bricks with very little compression. The SCE gaskets were softer and would compress a little better making a tighter seal. The only thing I had to do was trim them to fit the intake ports.
Snakebit
