Old 09-11-2010, 03:34 PM
strictlypersonl strictlypersonl is offline
All the signal light power comes off the same fuse (bottom, passenger's side), so it's not likely that is a problem. (Note that that fuse is dead with the ignition switch off.)
Do you have brake lights on that side? If not, check the fuses on the bracket under the steering column.
There's a more thorough troubleshooting process in my "Wiring Primer".
