Old 09-14-2010, 05:21 PM
John Martin John Martin is offline
Rick Lake , I talked with the teck department at Summit .I mentioned about cutting the weights off the clutch . He said he never herd of that being done or an issue .He asked if I was side stepping it , no I said and intend on shifting in the hi rpm once in a while , he told me I would not have problems with this clutch shifting it hi up the rpm range . The weights add clamping pressure .
For you and one other person ( Doug ) both giving me a heads up on cutting the weights off , I would like to better learn and / or understand the idea behind it .Do you think you can shed some light here on you take ? Thanks !
