Thread: Soft Top Frame
Old 09-18-2010, 05:44 AM
thatbluetruck thatbluetruck is offline
Cobra Make, Engine: E-M ford small block
Before I head off to the garage here's what did: I cut two inches off the vertical post of the frame to lower the total top height of the top. The fabric top was worn and needed to be replaced and I had always had a problem with the top whipping in the wind. It changed the "top hat" look of the original top (no roll bar). Also, add some heavy fabric straps from front to back which loop and slide through the frame of the top. This was done in the MG and Triumph car tops. I found it reduces the wind whip and the car travels better at interstate speeds.
