Old 09-19-2010, 09:03 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
First off I would check: Are the extra thick carb gaskets (between manifold and carb)?
It has been discussed earlier, and this seems like a very good solution. I use 2 x standard gaskets after boiling gasoline after the engine was shut dow.
(Sure boiled when running as well, but I never saw this.) In this way the carbs are better insulated from the inlet manifold.
RS
