Old 09-19-2010, 03:41 PM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
FWIW, went through everything, tried swapping the good firing #4 plug wire for the misfiring #1 plug wire...no difference. My final step was swapping spark plugs....voila! #1 started firing consistently, but the motor picked up a pretty bad backfire.. Replaced the spark plugs (had previously checked, cleaned and gaped them), put on a new stock coil, cap and rotor, and it is running fine now. I seem to need to retard the timing advance a bit now...getting closer to 10BTDC...but at least she is on the road again... At some point I still want to find a dependable local shop to fine tune this engine....As always I appreciate all of the input! Mark
"Freedom is only an illusion when the government has all the guns."
