Old 09-19-2010, 06:56 PM
dlampe's Avatar
dlampe dlampe is offline
I switched to an electric pump. It worked for a few minutes then right back to 6psi, washing down those new cylinders!
I have a 3 psi bypass regulator that I might put after the carbs and run that back to the tank. That HAS to work, right? If the first regulator falters, then the bypass should bleed off any build up at the carbs.
What regulator are you Weber guys running?
High Maintenance Racing Team
Run & Gun 2003 - 2013
