Old 09-20-2010, 12:35 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Sender Sealing
The fuel sender should be using a gasket and steel nut ring on the INSIDE of the hole cut out so you can properly tighten the bolts using a sealing/crush washer under the bolt head. It will leak and come loose repeatedly if you have threaded the bolts into the PP fuel tank material itself. I have also discovered that a great sealing crush washer to try on fuel tank flanges (depending on hole size and bolt shank diameter) that uses viton seals to seal around the shank of the bolt. They are called STAT-O-SEALS by Parker.
Check them out.
Pegasus Racing and others (Graingers, etc) sell these for many bolt sizes, designed for use in high pressure hydraulics, but with an encapsulated viton seal will work with fuels better than the plain nylon washers because it seals the shank of the bolt.
"...some assembly required, ages 8 and up...... well that took longer than expected......
