Old 09-21-2010, 12:18 PM
rustyBob rustyBob is offline
I have seen some people put a small dimple in the pipe where the head of the bolt makes contact with the pipe that way you can get a wrench on it.....or you can change to an allen head bolt....but as far as takeing them off.....someone got them on there so you should be able to get them off.....grind the wrench down a little on the ends so it dosent stick so far past the head of the bolt and try that ( use an old wrench)
