Old 09-22-2010, 02:44 PM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
the reason i asked is we have a prostock circle track car that the fuel pump looses its prime, i dont smell any gas so i would imagine the lines are not leaking?, we bought this car and only run it once or twice a year the lines are wrapped so it is hard to see, we have to run a vacuum valve that cuts out fuel delivery. we have changed the pump we have a fram canister style filter i want to take this out then i will remove the top of the fuel cell and take a look inside could be a craked or rotted hose or a cracked fitting ?.
i thought if i could pressure check the lines then i could move on to something else.
