Old 09-22-2010, 03:41 PM
Rick Parker's Avatar
I did it with 2 AN plugs. Drilled and tapped one for a threaded schrader air valve similar to that for a tire. Screw the plugs into the female hose ends of the hose assembly and pressurize (compressor is 125 PSI) then imerse assembly in water for a couple of minutes, looking for bubbles. Works well, about $10.00 per hose size.
Rick
