Old 09-23-2010, 03:26 PM
ZOERA-SC7XX's Avatar
ZOERA-SC7XX ZOERA-SC7XX is offline
You should be able to change the header gaskets without completely removing the primaries. Just remove the bolts and pull them back an inch or so for clearance. Just make sure you prop up the sidepipe with a jackstand. I installed mine without much trouble. Some bolts must be accessed from under the car.
