Old 09-24-2010, 04:44 PM
CJ428CJ's Avatar
CJ428CJ CJ428CJ is offline
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
The top rear bolt on driver's side is the only difficult one to get to (the others are easy as long as you have a flex socket and some long extensions for your ratchet). To get the rear drivers side header bolt off, follow the directions in the ERA Assembly Manual. There's a diagram that shows you how to bend a box end wrench to make removing that bolt much easier.
Chris
