Old 09-25-2010, 03:56 PM
blykins blykins is offline
Maxx.....It's not a hydraulic roller....it's a solid roller.
It's not an oiling problem either....
Capri.....
No, not enough spring pressure. I really don't understand how you're not having valvetrain control issues with spring pressures meant for a flat tappet or hydraulic roller cam.
As for the cylinder heads, you're pretty much stuck. I've never seen a factory or aftermarket head that would be cut out enough to get the lifters out. The whole pushrod area would need to be removed.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
