Old 09-26-2010, 02:51 AM
mickmate's Avatar
mickmate mickmate is offline
Hey Dan you can increase the depth some also. You probably won't need to with a heli-coil. If you do break through the threads can easily be sealed with a bit of silicon, thread sealer or PST on the threads. The tap will say STI on it which stands for standard thread insert then you'll have the thread size (3/8"?) after that. If you feel inside the coolant hole I believe there are bosses there for the holes you'll be able to get an idea of the depth. Pretty straight forward job worth doing to both while you're set up.
mickmate
http://www.actoncustom.com/
