09-26-2010, 02:41 AM
ESP
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
differential mesh pattern
The backlash and the bearing preload of the carrier is adjusted with the shims between the housing and the stub axle carrier.
The right side is for adjusting the the backlash, the left side adjusts the bearing preload.
After putting all back together I checked the mesh pattern, which looked e a little too much like top of tooth contact,
so I rearranged shims to take the pinion ou tof mesh and got the pattern on the pictures. Actually it did not change much.
Is this good enough ? Expert diff builder please advise.
Thanks
Nothing sounds better than a Cobra in a Tunnel !
Reason: pictures did not show
