  #26 (permalink)
Old 09-26-2010, 04:32 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by Wbulk View Post
OK, then check where the upper shaft and the lower connect together. It has to return to the stop by spring pressure. Take the points plate off. Spin it and play with it until you see when it will not return to the stop. Then see where it is hanging up.
Wayne
I will look at it again. The thing is that it does return easily by hand right now, but I guess there must be someplace that its hanging up at least a little bit.
www.partskeeper.com
