Old 09-27-2010, 07:32 AM
blykins blykins is offline
Iron/iron combos don't change much at all.
But the point is, on a solid cam, you don't want the operating lash at zero. Keep in mind that I said operating lash, because there are some special conditions (all aluminum stuff with tight lash cams, or hydraulic roller cams running solid roller lifters , etc.) where you have to set the cold lash at zero or near zero. When you get to that point, sometimes you have to preheat the engine before firing.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
