Old 09-27-2010, 05:51 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by jdean View Post
Vector,
I hope it is not washed out rings like you had. But I do not sense any loss of power either like you said. Did you lose any noticeable compression after your oil rings went loose? I have not done a compression check yet, but will in a day or two.
i really didn't have a loss of power that i could notice, i had plenty. when i did a leakdown the numbers were similiar, 1 or 2 maybe a little lower of which one had the compression ring gaps line up, i was generous with my ring gaps btw. my plugs looked similiar to yours, the bases were black but the porcelein looked good. the only reason i tore my engine down was a gasket that came out and the bearings were shot because of too much clearance. unless it is bad i wouldn't worry about your situation. have you ever seen an engine that had the crankcase vented to atmosphere, they will blow smoke pretty good.
